Discuss Injector Tee - How to Make Up One Onsite in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can anybody advise how to make up an injector tee without having to solder anything together? Tee being used is 22mm*28mm*28mm.
TBH it's easier just to buy one
Cut a 22 x 15 reducer down to a couple of mm . Insert this in the 22 end, with the 15mm part going into the tee. This leaves the 22mm end ready for the heating return.
Reply to Injector Tee - How to Make Up One Onsite in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hey All-- New here as this is something I have not had to do on this scale before. I am renovating our laundry room, which currently only has the...
Hi all, I need to fit a new rad but the location of it has an obstruction. I initially wanted to tee from the 22mm pipes but right beside them...
Hi folks, i've just moved into a property last month and begun to take note of things that may need attention. One of which is the feed to a...
Hi I recently did some pipe insulating in my loft. The only two I didn't do were the vent pipes. Not sure if that is the right term for them...
I have a water pipe (unpumped) from a stream in to my shed that houses a water tank. I require a continuous flow of water along pipe A in the...
