Discuss Inline scale inhibitor. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
TomLane
Have been asked what I would recommend for a inline scale inhibitor?
Not really my specialist subject area & would be interested to know for my own information too.
Thanks all.
just for a boiler or whole house?
I wouldn't recommend any of them. If scale is a problem, it can only be sorted by properly softening the water, not by an inline scale inhibitor. At best, the latter will only mitigate the symptoms - a bit like taking paracetemol for a headache, instead of having the brain tumour removed.
However, it isn't always feasible to do the whole thing, so if I absolutely had to, I would suggest a Hydropath HS38
But they are expensive, so people rarely take my advice and end up sticking in a £15 magnetic conditioner which might possibly have some benefit for a single appliance, but virtually none for a whole property.
We fit the hydro on all combis fitted on a housing contract. Thought they were cheap and cheerful. How much are they out of interest?
Thanks Rayvon, appreciate the honest advice!
How handy you just happen to be a stockist of the Hydropath's ;-)
We stock about 5 Tom, and the Hydropath is just the strongest dose of paracetamol - if you will forgive me for stretching the analogy from above.
Scale reducers are just that, reducers.
They will take out at best 1 degree of hardness. But if your water is 16-20 degrees of hardness, 1 degree is nothing. You still gave hard water.
They are not that bad at stopping to some extent, mildly hard water from depositing lime scale to a heat exchanger. But even then , it's hit and miss!
Like Ray says. It's like throwing a parecetomol at a brain tumour
Reply to Inline scale inhibitor. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi guys. I'm trying to identify a toilet model before ordering a seat for a customer. I went to what used to be a Roca stockist (they no longer...
I am in process of replacing an existing sink with a new stainless steel one. The existing tap is plumbed directly to copper which means that it...
