Discuss Inline scale inhibitor. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
TomLane
Have been asked what I would recommend for a inline scale inhibitor?
Not really my specialist subject area & would be interested to know for my own information too.
Thanks all.
just for a boiler or whole house?
I wouldn't recommend any of them. If scale is a problem, it can only be sorted by properly softening the water, not by an inline scale inhibitor. At best, the latter will only mitigate the symptoms - a bit like taking paracetemol for a headache, instead of having the brain tumour removed.
However, it isn't always feasible to do the whole thing, so if I absolutely had to, I would suggest a Hydropath HS38
But they are expensive, so people rarely take my advice and end up sticking in a £15 magnetic conditioner which might possibly have some benefit for a single appliance, but virtually none for a whole property.
We fit the hydro on all combis fitted on a housing contract. Thought they were cheap and cheerful. How much are they out of interest?
Thanks Rayvon, appreciate the honest advice!
How handy you just happen to be a stockist of the Hydropath's ;-)
We stock about 5 Tom, and the Hydropath is just the strongest dose of paracetamol - if you will forgive me for stretching the analogy from above.
Scale reducers are just that, reducers.
They will take out at best 1 degree of hardness. But if your water is 16-20 degrees of hardness, 1 degree is nothing. You still gave hard water.
They are not that bad at stopping to some extent, mildly hard water from depositing lime scale to a heat exchanger. But even then , it's hit and miss!
Like Ray says. It's like throwing a parecetomol at a brain tumour
Reply to Inline scale inhibitor. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
K
I need to change my scalemaster magnetic scale inhibitor as it is leaking but I cannot work out how to take it off! I ordered a new one the same...
We have a Daikin Air Source heat pump feeding our hot water and under-floor 8 port manifold heating system. The Daikin has just had its annual...
I saw on a plumerparts posts comments that the gas engineer always used an inline filter on the gas line to the boiler due to debris. I’ve just...
Hi All So with my new boiler on the way and to give it the best chance of longevity I am going to install a Scale reducer, we live in a part of...
I have a question that I’m hoping those of you who are experienced central heating engineers may be abler to throw some light on. But first I need...
