Discuss Installing a POWERDOCK or Power Dock into a GRANITE kitchen worktop. ********* in the Plumbing Jobs | The Job-board area at PlumbersForums.net
365drills
Power Docks are now the must have space saving device for kitchen worktops.
Whether fitted as an aftermarket item or as part of a new kitchen install a Power-dock or Power dock can add useful plug socket space and versatility to a work top area.
http://www.*********.com/jpgs/powerdock.jpg
Power Docks can add plug sockets to a kitchen worktop
saving on space and can be concealed when not in use.
One concern from installers is that there is a very low margin of error
for installing (drilling) the granite, marble or slate worktops.
Power docks are quite unforgiving on drilling tolerances as there is nothing
to hide the hole once drilled. So it has to be right first time!
At ********* we produce PORSADRILL. Its a value for money brand
of commercial diamond drills, cores and holesaws and perfect for
GRANITE, Marble, Porcelain, Travertine, Glass, Pottery, Slate and
a whole host of other stone based materials used to make worktops.
Click this bar to view the full image.http://www.*********.com/google/105mm.jpg
At ********* we make a range of large size Diamond core drills & hole saws
http://www.*********.com/project3/9.jpg
The diamod cores from ********* can easily cut holes into GRANITE.
http://www.*********.com/project3/10.jpg
Keep the core cool by adding water via a sponge.
http://www.*********.com/project3/13.jpg
Perfect Holes! And Ideal for electrical Power Docks
And if you cant lift or move the granite then its easy to drill in-situ
http://www.*********.com/bigholes/smaller/Dsc08131.jpg
Make a template out of plasterboard....
http://www.*********.com/bigholes/smaller/Dsc08143.jpg
Place the plasterboard on top of the granite worktop. Secure.
Start to drill your hole. Add water. And your hole is formed.
At ********* we make a range of diamond cores in all sizes.
Check out the website today.
Reply to Installing a POWERDOCK or Power Dock into a GRANITE kitchen worktop. ********* in the Plumbing Jobs | The Job-board area at PlumbersForums.net
