Discuss Intermittent drip from overflow pipe. in the Plumbing Forum area at UKPlumbersForums.co.uk.
  1. John P
    John P New Member
    Hi.
    I've got an drip that comes and goes from the overflow pipe from the black plastic tank above my boiler, which I think must be the feed/expansion tank. I had a new ball valve fitted by a plumber but still get a drip at times.
    I don't understand why, if the ball valve is working, there would be a drip sometimes but no drip at other times.
    Any advice would be appreciated.
    Thanks.
  2. JCplumb
    JCplumb Plumber
    Any new mixer taps fitted recently?
  3. John P
    John P New Member
    Thanks for your response.
    No new mixer taps. The only plumbing work in the last year was replacement of valves on the heated towel rail.
    John
  4. sammathias
    sammathias GSR
    Boiler overheating?
  5. Karl
    Karl Member
    Ball valve set up to high? Not enough room between water level and overflow to allow for expansion in the system?
  6. John P
    John P New Member
    Maybe. I've turned it down. Thanks for the suggestion.
    John
  7. John P
    John P New Member
    Hard for me to say. I had new ball valve fitted but it made no difference. Tank is so close to ceiling that it's impossible to see inside.
    Thanks for the suggestions.
    John
Loading...
Similar Threads - Intermittent drip overflow Forum Date
Intermittent hot water, 38cxi Gas Safe Registered Plumbers Only Jun 25, 2018
