Discuss Internal oil tank in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Last Plumber
Subscribed
This may be just the part of the world I'm in but I can't remember in my working life, seeing an oil tank inside a property before. ( commercial property) I know it's allowed but there are rules.
This one is face to face with the boiler ( 2 foot max away).
steel tank, no bund, no fire chamber/compartment, no ventilation I can see and no fire valve !
has anyone else seen the like ?
Yes. Worst one I know is a bungalow with garage at end. Small metal oil tank of about 1100 litre just above the boiler on purpose built walls in rear of garage. Been like that from the 1960s.
Sounds a similar sized tank.
The burner needs a new pump but it's around half price of a new burner.
If I end up replacing the burner I'll fit a fire valve, new filter and oil line but what about the tank installation?
It's been in for donkeys years but should it be updated
i.e. Is it a legal requirement or a recommendation
I am guessing, - but think that oil tank should be removed.
Contact OFTEC and ask them what the regs will be. Croppie should also know as he does commercial.
Any work you do obviously should be done with plenty of paperwork to state oil tank is a danger. Personally, I wouldn't do any work to the boiler until I spoke to OFTEC and building control
Recommendation only unfortunately. Document it and cover your a$$ that's all you can do. Last one to touch is responsible.
Probably 95% of the oil tanks I visit don't meet the current regs. Must cost me an extra box of biro's.
'Customer advised :- blah blah blah'
Day tanks should have all kinds of features including the bund.
The most important one is a fire valve which opens in the event of a fire and dumps the oil back into the main tank.
one wonders if anyone working on oil is oftec qualified and know the rules judging by the questions asked at times
Thanks for that Croppie but This isn't a day tank it's the main oil tank.
Emailed Oftec today cos phone line busy.
No reply as yet.
Yes I have a customer with a steel tank in a garage with the boiler alongside it. Its been there for about 40 years. Customer knows if anything needs to be upgraded then a compartment will have to be constructed which means the garage would have to be sacrificed meaning nowhere to put the car (there is no drive as it is directly onto the road and there are double yellow lines along the street, and there is no garden to put the tank in as an alternative). Another customer once had a boiler and tank next to each other in a hay store next to a stable. That was the first job I was asked to sort as their insurance company did a survey when the bought the property.
Reply to Internal oil tank in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Been in property about 10 years and the valve on the (round/bunded) Balmoral tank has always been in pretty rusty state. Tank is 5,000 litres but...
1K
First post as I can not figure this one out. I have a hot water boiler heating system, gas fired, with an HTP SuperStor indirect hot water tank...
Hi All, We have finally decided after a bit of a persuasion to have installed a utility room in our garage that currently houses our oil boiler...
Hello. I'm hoping to get some advice. I moved into a new build house a few years ago. A Firebird Silverpac external oil boiler (kabin pak type)...
1K
E
Hi all, Apologies if this has been covered elsewhere but I can't find an answer to my questions. I have a back boiler and gas fire which h has...
