Discuss Internal window sills in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
I don't know whether it's 'best' but this is what the local window-guy recommended when I had the same question:
It's got a shelf life of 12 months so get it from somewhere that has a good turnover of stock and check the manufacturing date, which is printed on the cartridge before buying.
If the gap is more than a few mm you are probably best to use some 'window sealing strip' and or some form of packing.
If you want to make a nice job, have a couple of practice runs first, or start on the least-visible section.
Reply to Internal window sills in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
How it best to install pipework to best avoid airlocks with gravity hot water. Install level or slightly down hill in direction of flow? Thanks
Hi All, does anyone know why the water only fills 1/3 of the way please?
