Discuss Is an upgrade to unvented worth the cost? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
V
VentOrUnvent
This is quite a long post... the gist of it is "is upgrading to unvented worth the extra cost compared to a straight boiler+pump vented upgrade?". There's a couple of other questions thrown in but that's the main thrust. Now some details...
We have a 5 bedroom, 3 bathroom house with good mains pressure (5.5 bar) and good differential pressure (3 bar) - I hope that's the right term to use - i.e. the pressure sustained when the kitchen tap is turned on. Our flow rate is also good at ~22 litres/minute.
Our current system is vented, boiler in the garage, ~120l cylinder in the hallway cupboard. The boiler is old and at 50 BTU is far too small for the house, which was extended a few years back without any upgrade to the heating system. We have all sorts of problems at the moment with rads taking ~90 minutes to start to get lukewarm and want that fixed so we can have a nice warm house quickly. Hot water recovery time is very good - 20 or 30 minutes to have enough hot water for a bath.
We also want to take advantage of technology like the Honeywell EvoHome to selectively and remotely control each room's heating.
We've had 5 heating engineers all recommend upgrading to an unvented system and moving the cylinder to the garage alongside the boiler. This has resulted in quotes of £7k+ (with the Evohome extra on top), with boiler suggestion around 27kwh (based on 14 radiators), cylinder size suggestions from 170-300l.
One heating engineer has suggested redoing the house's pipework into "upstairs" and "downstairs" instead of installing evohome. We've also been told by one person that we absolutely have to rip out all the microbore (and all the disruption that entails). We've also been told be one person that we definitely need an accumulator, the others have said not.
Adding into the cost factor we also have 2 Mira digital pumped showers to that's another £500 replacing those for the unpumped controllers.
We're struggling to know what the "right thing" to do is.
I guess our questions are:
- Is the unvented system really worth the extra cost of installation compared to upgrading the vented system? I understand unvented is "better", but is it £4k better?
- Should we replace microbore day 1, or is that something we should only do later after the system is cleaned and upgraded if we still have problems?
- Is the upstairs/downstairs pipework zoning worth the cost and effort when compared to putting in EvoHome?
- What size cylinder do we really need? We've had such a range of answers we just don't know how to estimate it.
- Do we need an accumulator with that pressure + flow rate?
Apologies for the long post but I appreciate any help you can give.
Extending property does not necessarily mean a proportionate increased in heat demand as new standards of insulation make property more thermal efficient.
An old 50 BTU boiler at 70% efficiency is giving no more than 11Kw output and this is undersize but equally 27Kw would seem oversized.
Check the circulation in your radiators by turning half off, the remainder should reach temperature in 15 minutes, if not the problem is circulation, pipework or pump, and with old microbore system I suspect the former.
Adequate sized pipework is essential for an efficient system, start by getting this right.
Vented or unvented your cylinder needs to be 250 litre+.
Unvented all day.
Even with the big price difference? Obviously everyone is telling us that's the best way to go - but we're trying to work out if it's worth spending an extra several thousand quid to:
1) Get rid of tanks (not a big deal, we have LOADS of loft space)
2) Get rid of shower pumps (pretty good, gets rid of noise in the morning)
3) Fill baths quicker (ok saves us 10 minutes 3 times a week).
What have we missed to justify the cost?!
Unvented shouldn't really cost too much, but depends more on the repositioning from original position of old copper cylinder.
Microbore pipes might be poorly done and too big runs, plus there is a risk your system might have sludge in rads & pipes, but would take a heating engineer to check that out.
It is really up to you, - if you are going to save thousands staying with a gravity water system that you are fairly happy with, then that's fine. But if you are doing major upheaval to your house anyhow, don't do it by half, do the whole thing to modern standards.
It's really how much money you can afford.
Put it this way, - although a fairly extreme example, - I had to do a large roof space conversion (heating & shower room) and this involved moving & replacing the copper cylinder on ground floor, which customer agreed would be best an unvented unit. It was a no brainer as cheaper to do unvented than run all the extra pipes up into a new attic and cwt etc for a gravity system would have cost a lot but no great water pressure.
When I came to join on to existing heating on ground floor & replace/add a few rads I found the Microbore to be full of treacle like sludge & rads same, plus the pipes were clearly too long runs. Microbore will not work over great distances.
Customer agreed to have me replace all pipes & rads and now has a brilliant fast working heating system & a high pressure water system and really for an extra £2000 I guess. She doesn't regret it and loves her shower
'Everyone is saying its the way to go'.
What else do you need to know?
The only thing I would add is that I wouldnt have the cylinder in the garage. Needs to be close to your main draw offs. Horizontal cylinder in loft space above bathrooms.
Doubling the output of your boiler will half the recovery time on your existing cylinder.
If this sorts out your heating you have money to spare for unvented. I suspect your problem is in your pipework and this should be sorted before any cylinder replacement.
The heating engineer who is best to replace your boiler may not be interested or even best suited to rectify pipework in existing occupied property. Do the work in stages
Fair question - but as above really, do the benefits warrant the additional costs (moving cylinder, altering pipework, replacing shower controllers)?
I haven't quite seen a convincing argument - although it would be a no-brainer decision if there were no or only a very small cost difference.
Plenty for me to think on clearly.
Point taken on the microbore for those saying that. My plan / hope is to install the new system (as the boiler really is >10 years old so presumably really inefficient) then once all the pipes and rads have been flushed and we have a decent pump, see how it performs. If it's still slow then we attack the microbore (which is only on the downstairs rads) - that means a lot of mess and plastering so I'm not going to touch it if I don't have to... but if it needs doing I definitely will.
Stay vented, no problem. That will save you the annual service on the unvented cylinder as well.
Reply to Is an upgrade to unvented worth the cost? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PSxxxxxx
