Discuss is it ok in the Plumbing Jobs | The Job-board area at PlumbersForums.net
E
eddiebrown424
to pressurise the primary side i.e. heating on a vented cylinder. I was told it is ok but it doesnt sit right with me I would prefer one system or another but of cours I am probably wrong.
eddie
Of course it is as its the hot water thats vented. Cyl stat for control
As long as the pressurised circuit has appropriate safety ie prv, ex vess .stat
Yes. you wouldn't normally put more than 3 bar into it. Don't forget to install a prv, expansion vessel and controls.
Eddie, Kris is of course correct. This is how a 'system' boiler works, either Gas or Oil. As long as the Cylinder is a Double Feed Indirect to BS1566 Part 1. The primary (heating) water and the secondary (domestic hot water) are separated by a physical heat exchanger or 'coil'.
An electrical Cylinder Thermostat will control the primary circuit via a motorised valve.
Thanks guys wasnt sure re the coil in a vented but thats why i love it here so much knowledge......
cheers
Eddie
Reply to is it ok in the Plumbing Jobs | The Job-board area at PlumbersForums.net
The left rear floor corner is highest (the shower pan touches/sits on the floor), sloping down diagonally to the front right corner (lowest). The...
