Discuss Is it possible to connect a bath to a macerator? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Planning to install a Sanniaccess 3 or Grundfos Sololift2 WC-3
Primarily for toilet, basin and shower use but the shower will be over a bath with occasional bath use only.
Read all sorts of information (including RPM's 10 golden rules) but unsure whether I can connect to a bath (with correct pipe fall)?
(Lift will be 3.5m in 22 mm then 7m fall to soil connection in 32 mm)
Jo
Shouldn't really connect a bath to either of those pumps.
Whilst neither have the approval rating both will do the job however you can throw the warranty away.
Oh, that was from Saniflow technical dept. Difficult to know who to take advise from. Thanks for the reply anyway. Is there another alternative?
Did you mention the bath, if so then you were misinformed by a muppet of which there are plenty in that office.
Product details for SANIPLUS
It`s the same for the access range I`m afraid. Other than 2 pumps just do it with a Saniplus Jo and as I said throw the warranty away after 2 days use because if it works for 2 days it will work for 2yrs PROVIDING you understand the pumps limits of what it will cope with.
(Nods to quality for his kind words.)
Hi Jo the boat,,,, i know youve said its for wc, basin and shower which it will do no problem but the issue is the bath, the only one that will do the bath is the saniaccess pump but obviously wont do wc,
Err, You forgetting the Sanivite or the Sanispeed, the Sanicom range or the Cubic range then kris.
Reply to Is it possible to connect a bath to a macerator? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down through slab and out through deadwork into a manhole. I will work out falls from manhole and set the height of the waste water system as required. For...
