Discuss Is my boiler condensing? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I have an Ideal Vogue C40 Gen 2 40kw combi boiler hooked up to a 10 radiator CH system. Recently I have balanced the rads and now have a feed temp of 60 and return temp of around 40 degrees. I’m not sure the boiler is condensing. There’s plumes of vapour coming out the flue and the onboard efficiency monitor seems to always be at 40%. Any suggestions?
Return is well below 50 yes it’s condensing ignore the efficiency bar
Have a read of this it explains it better than me
Reply to Is my boiler condensing? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
