Discuss Is pvc pressure water pipe okay for outdoor use? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I've just put a second tap out in the garden and ran that 1/2" pressure water pvc to do it. Down from the first one, underground, up to the second.
The up and down runs exposed to the weather all the time.
Is that going to be alright or I should clad them or paint them or something, protect them?
I see pvc downpipes and such don't seem to need any protection.. and I see a bit of this small diameter here and there but not much of it...
I hope you used pressure pipe glue for the joins.
If not, keep a drawing of where the joins are.
Pressure pipe is ok for mains pressure, but the joins can be suspect
Reply to Is pvc pressure water pipe okay for outdoor use? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi all, Have got an old 60/70s PVC soil stack, the Toilet is going into a Hunter branded socket which has an old O-ring design (quite flat with 3...
Hi I've got water hammer issues with my cold feed and some with the hot feed. When the cold sink tap, cold bath tap and thermostatic shower in...
This issue arose about a year ago. Does anyone have an idea why I occasionally hear (about once every hour or longer) a hammer related noise...
Hi All After having pooling water on my drive, I dug down around to find: Black pipe poly/plastic dug 450mm deep spraying water at mains...
