Discuss Is there a direct replacement for wirquin jollyfill please in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Phil999
Hi
Have a cistern with a jollyfill valve and flush
The inlet pipe valve part on the rhs connected to the water inlet is leaking
on the pipe\ flexihose
Is there a direct replacement of another make that can fit.
Also there is a flush part that connects to the dual button do I have to replace that part as well, ie is it both parts I will need to replace
Thanks,
Phil.
Best, would be to remove the flush valve and fill. Then replace with one of these.
Fluidmaster Pro Universal Cistern Pack
Probably the best and most reliable out there
Reply to Is there a direct replacement for wirquin jollyfill please in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Does anyone recognise the make/brand of the radiator valve. It leaks when closed and Iam hoping I can replace a seal etc?
Sonya K
