L
leedx7
Hi there, just stumbled on this forum as I panic search for advice.
I have recently had an Ideal Logic+ combi condensor boiler fitted. It is in the old airing cupboard with a flue and the condensation pipe running outside. The condensation pipe is 22mm internally and externally. It's lagged and runs almost horizontally (the missus says it is horizontal, but I doubt that) along the north facing outside wall of the house and into a gutter.
As you've probably guessed, it froze and the boiler cut out.
I have twin baby boys so the heating can't be left off, especially now.
The wall on which the boiler sits backs onto the boys' room.
I called the installer (as I had no idea at the time what had caused the boiler to cut out) and he cut the condensation pipe below the boiler and told me to put a bucket there. He would then return in a few days with a push fitting.
2 days later he finally rings telling me not to use the boiler as it will expel fumes into the house! This came as a bit of a shock! The boiler needs to be on, and it's right next to the kids room! He is going to try and come tomorrow to reconnect it (presumably using a pushing fitting?).
On reading the interweb, it seems that fumes should be stopped by either the flue or a trap in the boiler. How can I know if the trap is full or that the flue is working? Is there a real risk of fumes in the boiler? Will leaving the boiler off make it safe? By "off" does that mean off at the mains or can I use hot water?
We have a carbon monoxide detector placed next to the boiler, but is that the fumes being expelled?
Any and all advice would be gratefully received.
Oh, and if he does refit it, and assuming it re-freezes - would a wider external pipe make any real difference?
