Discuss Is this fitted correctly in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
Radioman
As above, is this correctly installed or not
Ok I was just concerned as it has been left pointing up to collect the rain
That was my thought too. I'm not GFR registered though, so don't put too much value on my opinion on this.
You can check for yourself by downloading the info from the worcester website.
It's too long though
Pointing up is okay, it's just a plume diverter. Any rainwater small amount would flush through the condensate anyway.
I don't normally leave any white pipe sticking out as it's a bit lazy, the rubber ring sits in a recess on the black plastic if measured correctly but it's not the end of the world!
As above. That's fine. If it was pointing down there is a chance of it blowing all the fumes in your face as you walked below it. Rain will just filter through and down the condense pipework. All good.
Reply to Is this fitted correctly in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Pipes for thermostat shower have been fitted at different heights. Any way of rectifying without ripping all tiles. So for clarity 15mm pipes...
Can anyone recommend a decent multi meter, preferably under a 100 pounds. It's for checking boiler components so I don't need a top spec one...
