F
familyguy
Would really appreciate your thoughts on the quality of this plumbing and whether you consider it to be sufficiently weather proof, bearing in mind this is in the loft and the cold weather we've been having the last few winters.
I have a few lay persons questions:
1. Is it true that all parts of the pipework and joints should normally be covered by insulation?
2. Also the grey plastic pipe corner seems to be at an odd angle to me, is that good practice/safe or does that not really matter?
3. Should the electrics (e.g. where the bare bulbs are connected) be so close to the pipework including in some cases directly below it? Is that safe/good practice?
Many thanks in advance.
David
