Discuss Isolation valves - saving water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
mo7
I am looking to save water - primarily by adding after market products to my shower and taps to reduce flow rate.
The water companies offer many products to reduce flow rate on visible pipework but my plumbing work has isolation valves on every pipe before every tap.
Is there any reason why I cannot just adjust the isolation valve to reduce flow?
At the moment mine are fully open and obviously only closed for maintenance - I am not sure if they are designed to be half closed for general use... ?
No that is not the way to go bud you will cause noise desturbance up the pipework your valves will sieze half open and you still have no way of knowing how much water your using , contact your local water company they can advise you on ways to save water many also offer products free of charge which you can fit ,they will look something like this mate cheers k
They make isolation valves with flow restrictors to specific flow rates.
Thanks, yes I did see that you can get special isoaltion valves but I bet with my luck it is not a case of just switching them over. I think it may be easier to go with the end user fitted bits as above.
Reply to Isolation valves - saving water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
Hi all! I'm in the process of fitting a replacement undersink water heater in my shed and, as advised in the instructions (yes, I know, what am I...
Hi All I had an unvented cylinder fitted about 6 years ago. It only supplies hot water to my shower. I was hoping for a much better flow rate from...
Steveo111
Hi I have always had a poor water delivery to my bathroom and en-suit basins. The cold is just about acceptable but the hot is pathetic coming...
M
Hello, I have a new unvented system with a horizontal 210L Joule hot water cylinder. The cylinder has been vibrating badly which you can hear...
