Discuss JG or hep fixings for pipe extension? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Want to extend a rad. Need longer pipe work. It say H & B on the flexi pipe (10mm) will this be JG or hep fittings. Just need to extend around 200mm. Thanks
Doesn’t matter on fittings just the inserts as you have a fitting on the end there will be an insert in there so reuse that and carry on in either manufacturer you want
Reply to JG or hep fixings for pipe extension? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
