Discuss job roles in the Plumbing Jobs | The Job-board area at PlumbersForums.net
sandy
i am researching a possible career change and im getting confused as i am trying to take in as much info sa possible.
would a compitent plumber who is qualified to nvq level2 be able to install full central heating systems? or am i right in thinking that the plumber would do all the pipe work and then a gas registered plumber would do the boiler and associated gas work?
also would anyone mind posting a list of typical jobs a plumber with nvq 2 would expect to undertake, i will start the list and woud appreciate if you could add/remove
cheers
- fit out bathrooms
- fit external taps
- fit dishwashers / washing machines
- fit central heating (minus gas)
- leadwork
- renewables (installing solar heating etc)
- fit out bathrooms - Yes.
- fit external taps - Yes.
- fit dishwashers / washing machines - Yes.
- fit central heating (minus gas) In theory but customer just hires the bloke who will do the lot. If you're working for a firm that does central heating installs and you're level 2 you might do this.
- leadwork - Not really. It's mainly specialist firms. Old-school plumbers might. The guy who taught me does.
- renewables (installing solar heating etc) - If they've got the applicable extra qualifications. It's a specialist wing again. Level 2 doesn't cover it.
You basically work with all wet-plumbing. Taps, toilets, valves, leaks, cylinders, bathrooms, radiators etc. Repairs, replacements and new installations.
Don't forget that you work with what the customers wants/needs (within regs)If they let you!!!!!!They can be more problematic than the system problems!!!!LOL
Reply to job roles in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A bit of clarification - I have extended a 3 bedroom semi detached and at the time central heating pipes were going in I told the plumber could I...
I am starting a large victorian renovation and it will involve, (amongst everything else) installation of an entirely new heating and plumbing...
J
Hi all, I am a plumber but I do not carry out works to boilers as the majority of my is bathrooms so I am not gas safe. I have completed a...
L
Hey everyone, I'll keep it short. Had our old system boiler replaced with a new Ideal system boiler set up. Then the problems began. First...
2K
Hello everyone, We have recently moved to the UK, so really don't know much about gas central heating and boilers over here etc. So this is...
