Discuss John Lewis ceramic mixer tap washer replacement in the USA area at PlumbersForums.net
Hi I have a John Lewis kitchen mixer tap but can’t see the item name just JL. Does anyone know what replacement ceramic washer I’d need?
It’s approx 5-7 years old. Many thanks
475.1 KB
510.4 KB
Probably 3 options available:
- Speak to John Lewis customer service (I believe the taps could be made in Italy)
- remove insert/cartridge, and take to merchants/diy chain
- renew the tap instead of faffing about
good luck
Subscribed
Even if you found the make it wouldn't help much in identifying the cartridge.
It's probably just a standard cartridge that you need.
You'll have to remove the handle first and check the number of splines on the end and length of shaft, then get some from Screwfix or similar.
If the Screwfix don't match there are loads of suppliers online, just search Ceramic tap cartridges.
Or a local independant plumbing supplier.
https://www.NoLinkingToThis/c/bathr...agedredirect-_-plumbing-_-ceramictapvales#_=p
Reply to John Lewis ceramic mixer tap washer replacement in the USA area at PlumbersForums.net
Hi I have a John Lewis kitchen mixer tap but can’t see the item name just JL. Does anyone know what replacement ceramic washer I’d need? Afraid...
I have read a few threads including one by Debbie Stano that were similar to my issue but that thread stopped a while back without any resolution...
Can an old mixer tap leak uncontrollably?
The mixer tap in my kitchen is very old,maybe nearly 20 years. For the last year or so it has been...
Bath mixer tap manufacturer identification
I have a drip on the cold side of my quarter turn bath mixer. I cant isolate the feed as the isolation...
