Discuss Kitchen extractor ducting to boiler to boiler flue. in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
T
TenementConservation
Morning,
Im in a top floor tenement flat with access to the attic space. I have a combi boiler with flue that emits vertically up through the roof. My kitchen is situated internally with no easy access to an external wall. Could I fit a kitchen extractor that ducts vertically then right angles and connects to the existing boiler flue with a t piece connector? Is there a way to make sure that any CO would not be able to come back down through the kitchen ducting, and would any of this conform to regs?
No no no no no ! There absolutely no way you can do that conform to reg it just about breaks every one šŸ˜‚ , get a professional in and avoid hurting yourself or someone else. Kop
Reply to Kitchen extractor ducting to boiler to boiler flue. in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
