Discuss Kitchen mixer tap problem - can't disassemble... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone. I thought this would be a simple job - fixing a leaking kitchen tap. I took the cover off, removed the screw and expected the tap head to come off. I can't figure out how to get it off. The assembly is shown in the photo below. How do I get the tap head off to get at the washer?
tap.jpg.html
Please...
Looks like it is on splines, should pull off, been there for awhile so will probably need encouragement ie tap tap with a mallet or 2 screwdrivers to pry it off. Mind your knuckles if it suddenly gives!
Edit, can`t see clearly but is that a circlip I see?
No, it's just a plastic rim as far as I can tell. Seems to be ready to break up. I'll try pulling the tap head of as you suggested.
Reply to Kitchen mixer tap problem - can't disassemble... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
