Discuss Kitchen sink waste queries in the Plumbing Jobs | The Job-board area at PlumbersForums.net
mo7
I am re-doing my outside drainage (see separate thread). It is an ideal time to re-jig my kitchen sink waste as it is taking up too much of my cupboard space.
I had an idea of what I wanted and found that in fact McAlpine already make a product with the correct configuration which sets the pipes backwards towards the back of the unit/wall..
See photos of old setup and new product I bought.
As you can see I have 2 full bowls.
Shared photos 5-3-2017
My queries
1) I have to use the appliance waste which is 'half' open - is this OK for washing machine? The waste on the other end is a full opening but it would not go in as nicely as the way I want
2) is it OK for me to put the waste outlet the direction I want - so the water comes down on a slope left to right but then goes back on itself - I presume it makes no difference. I would then cut the waste pipe back so it comes in and bends much closer to the wall.
3) is there a minimum i should have it standing of the wall? I presume I only need enough space to be able to undo any nuts.
I tested 40mm black pipe on the end of the trap and seems to work - so presume this is fine and how it should be done.
1) Should be fine, - the division is to direct the water flow
2) Yes, probably
3) Just keep the whole lot close to the wall to whatever you need for space for nuts to turn. Doesn't need to be very close though, - you could keep the space behind of 25mm or more if you wanted. The first bend when it comes through wall will be the fixed distance, so get it right.
Careful measuring the bent pipes that join to wastes and go back towards wall. You won't have spares if you cut them too short
Reactions: mo7
Reply to Kitchen sink waste queries in the Plumbing Jobs | The Job-board area at PlumbersForums.net
    • Useful
My parents have a leak from kitchen sink. My dad removed waste trap and since refitted it leaks, but there wasn’t any kind of seal on it, I got a rubber/plastic gasket that seems To fit the trap but with it, I can’t get it to screw and lock back on (has lugs so locks after quarter turn. But...
I am installing a sink in utility room. Washing machine waste already exists and is the verical pipe with the flexib pipe from the machine poked down the top and a with a u bend at the bottow going directly to outside drain. Is it OK to put a tee joint into the verical pipe and join the sink...
Good afternoon, Just looking for some general advise, I'm renovating my kitchen and need to disconnect my kitchen sink pipes while I re-plaster the room and wait for my new sink to arrive. So I need to temporary cap off the two below connections cant seem to find what is the best way to do this.
Hi guys, just want to get advice, i want to replace venten to unvented cylinder, is it ok to install D2 pipe to toilet waste pipe see picture? as there is no easy options to get it outside.
Hi, I need some advice connecting my bowl sink to the waste. There was a Insinkerator installed that I have replaced with basket strainer waste (Viva PP0011). I need to connect the waste but I find myself going around in circles in regards to selecting the correct parts. Thanks FrankW
