Discuss Kitchen tap gland 1/4 turn in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
My tap started dripping & I used my trusty monkey Wrench & tried to brute force it to turn. Sadly the nut round off & I can’t seem to remove it. I purchased a spanner but still no luck as the nut has no corners.
I tried the monkey W again on the base but the metal has turned soft. Any ideas on how to remove or go full brute force on the gland till it turns.
Only a few things left to try with that one:
- Apply something like crack it spray
- Apply heat, such as blow torch or pour boiling water over it
- New taps
Reply to Kitchen tap gland 1/4 turn in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Our kitchen mixer tap has started dripping. Like so much of the plumbing in our almost new build bungalow, it is lacking! The plumber didn't...
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking?
This originally happened about 12 months ago and has happened 3-4...
I have a plumber coming tomorrow to change a cartridge on a badly dripping tap on my bathroom mixer unit. There is no separate isolating valve for...
