Discuss Kitchen tap thread size in the DIY Plumbing Forum area at PlumbersForums.net
Hi
I need to replace both hot/cold taps as they have done 20 years service, I looked at various sites and the thread size is quoted as "G1/2" now the dumb bit, is this referring to the copper pipe size thats fits into the tap or is it the external thread size f the tap.
Thanks for any info.
1. It is the external thread size of the tap.. "G1/2" is 1/2" British Standard Parallel Pipe. This has a major (over the threads) size of about 21 mm (0.825").
2. These are normally connected to copper pipe with a tap connector, which will have a 1/2" BSP female thread at one end, and a compression or capillary soldered connection at the other end for 15 mm pipe. A fibre washer provides the seal between the tap connector and the end of the tap's threaded shank.
3. The above assumes you have separate hot and cold taps or a bridge mixer tap. If you have a monobloc mixer tap it is likely to come with flexible hoses or copper tails which may have a different termination.
Thanks you for your detailed reply it was very helpful, have now replaced taps and all good thanks.
Reply to Kitchen tap thread size in the DIY Plumbing Forum area at PlumbersForums.net
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
