Knocking in pipes
Discussion in 'Plumbing Forum' started by Sphere25, Feb 21, 2016.
Discuss Knocking in pipes in the Plumbing Forum area at UKPlumbersForums.co.uk.
Thread Status:
  1. Sphere25
    Sphere25 New Member
    I have a top level flat which is experiencing intermittent knocking in the mains pipe.
    I have been experiencing this issue for a couple of months now and am none the wiser as to the issue. It appears to be quite intermittent in, however there seems to be an increase in the frequency during the evening, between 8-10pm. It doesn't appear to be connected to anything in the flat as it seems to trigger even when no water has been run for a couple of hours.
    I did wonder whether it was possible that this was either the effects of another flats water hammer combining with a fault in our stop cock or air in the system. We did have a pressure arrestor fitted onto the boiler inlet however I don't think that has had an impact.
    If anyone has any suggestions that would be very useful before I try and start paying the call out charges for each attempted fix!
  2. Knappers
    Knappers Plumber GSR
    Hmmm that hammering does travel.
    Several causes, including over enamerous downstairs neighbours!
    Usually a washer, diaphram or pressure issue though.
Loading...
Similar Threads - Knocking pipes Forum Date
Gas pipes and cables Gas Safe Registered Plumbers Only May 23, 2018
Cables and gas pipes Gas Safe Registered Plumbers Only May 23, 2018
Thread Status:
