Discuss Laser level recommendation in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Just wondered which laser levels are good all rounders for accuracy, ease of use, price etc… Thanks in advance.
Green laser is best and ideally a brand name but for the occasional DIY'er putting up shelves or tiling you can manage with a red laser. My Bosch is nicely made and ideally use a laser pole so you can set it up at any height.
I have a Hilti green laser from 2017 hasn’t failed me yet touch wood :D
I have a blue Bosch one with tripod, been great but I do find the red line can be difficult to see on bright days. One of my lads has a green Dewalt one and it is definitely clearer, but dearer so depends on how much your planning on using it.
Reply to Laser level recommendation in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
  • Sticky
