Discuss Last tool you bought, next tool you're buying? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Dan
Administrator
Staff member
Admin
What was the last tool you added to your arsenal?
And what's the next you're considering to get?
I've just spent £297 on a Sigma tile cutter, I have to watch what I say on the tiling forum as I'm a plumber and they probably picture a gorilla trying to use a Macbook pro, well thats not the case at all.
My next tool is a new planer just as soon as Axminster get them in stock.
Reactions: Dan
I have bought my tool bag which I consider as my tool too. I am looking forward to buy a crimping machine at some point.
Reactions: Dan
Ace, didn't realise you were on there lol
They're all banging on about those these days over Rubi. Apparently Belotta are making some good ones too.
A nice new pair of 22mm copper pipe cutters. Next tool will probably be a hammer as I seem to loose mine once a month :)
Reactions: Dan
Just got a nerrad 15 mm pipe cutter. Quite impressed with it. Been eyeing up laser levels so might get one of those next.
Reactions: Dan
Nerrad that's the one I got. Im fed up with crappy rothenberger cutterd that fall apart after a couple of weeks.
Last tool 2 Ox pipe slices
Next tool Milwaukee M12 bandsaw
Ryobi mini grinder
Looking at multitools at the moment....have champagne tastes but only lemonade money lol..regards Turnpin:)
Kane 456 as old 455 got damaged beyond repair
Ryobi mini grinder
I was the same as you mate, I never felt the need for a multi tool.
18 months ago I bought (what I thought) was a crappy 15 quid Ryhas (sp) multi tool off flea Bay. Came with about 20 accessories.
I've used it no end of times and the bugger won't die! Have put 1 new blade on the circular one and one plunge blade in all that time.
I will upgrade when this dies but it's been brilliant! Floorboards, steel conduit, wood, it hasn't skipped a beat and it's been battered. Only downside is it's not 110v.
If interested I'll get you the link.
Jon
The thing to remember with multi tools is that whatever you are cutting needs to be secure as they oscillate. If it's loose all it does is bounce everything around and you get nowhere. I think this is why some people hate them as they don't get how to use them.
Jon
Can't recommend these enough. I've had a set for 12 months roughly and they are brilliant. Have the 15mm and 22mm. They also do a ratchet cutter for tight spaces.
Talking of Nerrad, get a Nerrad-versa-funnel it is so bloody useful! I thought it was a gimmick but it saves PCBs, carpets, acts as a bowl. Top tip # 3
Nerrad-versa-funnel
Jon
Oh and I have no affiliation with any of these I'm just an engineer that likes things that work and makes my day easier.
Jon
Jon
Hi Jon and welcome to the forums....yes that would be helpful probably do me for the time being just for bits and pieces around the house..great when you get a review from someone who has tried it out...have looked at a few but doesn't really justify the money for the use it would get from me....regards Turnpin:)
New 18volt brushless grinder. Burnt the old carbon brushed one out on Saturday. It actually melted the carbon rushes into the body! Mind you it had a hard life.
The new brushless one is amazing.
What brrand did you get?
Just got a nice little 6' rothengberg adjustable spanner. Has very wide jaw no problem gripping 22mm.
Good for tight spots.
Just bought a set of small warding files. Next buy will be a 5inch hole auger !
Rothenberger waste pipe cutting set, although you need a grip like a boaconstrictor to turn the things.
Nah, if you have arms like Micky :) then maybe yes. But usually it's fairly easy to turn them unless in an awkward position
i find technique help,
pop it onto the piece you want to cut,
turn it abit by pushing along the open edge following the arrow of rotation
and then you should be fine to grab and twist easily
if it tram lines your not griping / squeezing it hard enough
If you also hold the opening too tight it's very difficult to twist them around. I'd put my hand right opposite and then start twisting it's so much easier
Reactions: Dan
Reply to Last tool you bought, next tool you're buying? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Sticky
We have 2 brand new cordless, battery powered press tools in stock, and flying off the shelves. Our TekTools TZ1930 & TZ1550 are packed with...
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
My son has an apprenticeship interview for to become a plumber and heating engineer. The have said there will be a multiple choice exam for this...
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
