Discuss leaking around soil stack junction in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
adp
There are leakings from two ends of a junction which connnects the main pipe above and the clay below as you can see from the photo. I'd be grateful if anyone could give me any idea how to fix the problem.
Another leaking is from a stap boss around the soil stack. Should I take the old boss off and replace with a new one? Do I need to worry about the solvent weld?
Replace it with a new pipe and fittings its a mess. Cost about £80 - 110 for materials
Use terrain solvent weld pipe.
Thanks for quick reply.
Do you mean replace the prooblem pipe and juntion from the ground up to the first floor juntion or the whole soil stack from the ground to the roof?
Is it easy to get part of pipe and juntion replaced and properly connected? I auume I can't lift the pipe up.
Reply to leaking around soil stack junction in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I'm a DIYer and have a problematic toilet setup to fix: The waste pipe was installed too high for waste to flow out from a standard toilet...
Trying to connect up new 40mm waste into the old soil stack (which would be an absolute pain to remove), it's all Osma pipe, from the 70s...
1K
Hey all, I’ve got a new section of stack fitted but when I fitted the strap boss I was too keen to test it and it now slightly leaks where it...
Hi all, Have got an old 60/70s PVC soil stack, the Toilet is going into a Hunter branded socket which has an old O-ring design (quite flat with 3...
Morning all, as always can never find an exact existing thread / discussion where I don't feel like I'm making one too many assumptions. Can I...
1K
