Discuss Leaking joint on bottom outlet oil tank in the Plumbing Jobs | The Job-board area at PlumbersForums.net
B
Bob foster
hi there Hope you are all well. I have a leaking bottom outlet on oil tank, it is dripping at the connection for the stop valve. Unfortunately just filled tank with 2500 of oil, is there any temp repair I can do until tank is empty to enable a permanent repair.
Regards bob
Nope. Speak to oil supplier. For a fee they will pump out whilst repaired and pump back. Take measures to conrain leak before it becomes notifiable to environmental protection.
Thanks for that. I was hoping there might have been a temp fix until oil runs out
Kind regards bob
Reply to Leaking joint on bottom outlet oil tank in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
PSxxxxxx
