Discuss Leaking safety valve in the USA area at PlumbersForums.net
Hi everyone, I’m completely new here and just signed up.
My Termet boiler has been leaking for a while, and I’ve been procrastinating honestly to do anything about it as the weather has been warm.
Yesterday my wife turned the heating up to the max which I told her not to do, anyway water was everywhere of course.
After reading a lot and watching some videos, I’m sure ( but please correct me if I’m wrong) that I need to replace the pressure relief valve. Also I assumed the expansion tank might need replacing too but when I opened the top part, I can’t see one??
Any tips on what my next step should be?I’ll include some pics.
Thanks!
1. I note you are in Poland, so the rules on who can do what with a boiler may be different from the UK.
2. I'm not familiar with your make of boiler, but it looks like an open vented (regular) boiler which has been attached to a sealed system. If so, expect to find the expansion vessel somewhere else.
3. The expansion vessel outlet should be connected by a copper pipe to the outside of the property. In the UK the end of this pipe would be "turned back" against a wall, usually by an elbow and a 45 degree fitting.
4. It may not be UK rules, but I would strongly suggest you leave meddling with the boiler to a trained and certified person.
Okay thank you!
I’ve taken both of pieces of advice and put the casing back on.
I assumed replacing both parts I mentioned would be a case of turning off, draining and replacing, only dealing with water, not gas which I don’t want to touch.
I presume the expansion tank is in the basement or attic?
One more question this casing that I took off, does it need to be 100% airtight? I don’t think so, but now after putting it back on the thought just occurred to me.
Reply to Leaking safety valve in the USA area at PlumbersForums.net
Hello I’m hoping for some perceptive / input as I’m a long-distance landlord trying to unpick the best thing to do. Gas safety certificate was...
In our sealed Megalo system, when hot water tap is used (say in bathroom shower) the megaflo is taking in some fresh water, I guess to compensate...
Hi Just had a new bathroom installed with a toilet bowl that reaches the back wall. Its has a bottom entry cold feed to the cistern. The fitter...
1K
Hi, I have I blend valve from Nu-Heat ( they bought it from Reliance, as per attached spec). I have dismantled the valve now 3 times and...
Hi, I have an unvented water heater which for some reason every year causes me issues. At the end of 2023 I noticed that the pressure valve...
