Discuss Leaking spindle on LSV in the DIY Plumbing Forum area at PlumbersForums.net
The spindle on the LSV is leaking and I don’t fancy changing the valve for fear of starting with one leak and ending up with three! So, I am going to try the trick with Loctite 55 and wrap it around the spindle and put the nut back.
My question is, should I also use a dab of hawk white or perhaps a small amount of silicon grease, or will this have no benefit at all? I have all items at my disposal so that is not an issue. Is there even a better way that I haven’t already mentioned?
TIA
yep time to repack then just there maybe an oring on the spindle thats gone if not no need for any grease etc
Can you go any more and did you give it chance to dry?
I can perhaps try tightening it a bit more, but not sure if it is as realistically as tight as it is likely to get.
Not sure what you mean about giving it chance to dry? I tried it off with a tissue after tightening it up and it has certainly improved, but as I say it is still slightly weeping.
If it’s tight I would say time to pack
Reply to Leaking spindle on LSV in the DIY Plumbing Forum area at PlumbersForums.net
Hi. I've decided to start another thread to resolve this specific issue. I have just replaced three leaking Drayton Drain Off Valves. After...
8K
  • Locked
Hi and thanks in advance for any advice It’s a little long as quite simply I need to be sure whether I can get a free repair as it’ll be after...
6K
