Discuss leaking tundish and electric flips in the Central Heating Forum area at PlumbersForums.net
water constantly running through tundish and electric flip when turn heating on.
IMG_20220614_103518568.jpgIMG_20220614_103448451.jpgIMG_20220614_103454906.jpgIMG_20220614_103507412.jpgIMG_20220614_103437123.jpg
Needs servicing ASAP by a plumber who is qualified to work on unvented hot water systems, also known as 'G3 qualified'. Check they have this when making your booking.
Not a DIY job, I'm afraid.
Reply to leaking tundish and electric flips in the Central Heating Forum area at PlumbersForums.net
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
PSxxxxxx
Hi all I need to run this CH pipework to a radiator located beyond the electric wiring in the image below. Just to be safe I was wondering if...
