Discuss Like counts will be back don't worry :) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Dan
Administrator
Staff member
Admin
Just letting you know the likes counts will be back. Don't worry. :)
Likes counts should be correct within the hour. They're being imported now and the import is going well.
Imported 293,360 items. (6 minutes 31.05 seconds)
Cheers Dan. Will the thanks given/received be back as well? I really liked that feature.... :)
Afraid not pal. That's something we lost on all forums.
Reply to Like counts will be back don't worry :) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can anyone recommend a decent multi meter, preferably under a 100 pounds. It's for checking boiler components so I don't need a top spec one ....just easy to use and reliable. The fluke 115 looks good but its above my budget. My current socket and see one was great but it's developed a fault.
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
