Discuss little wiring help 🙏❤ in the Central Heating Forum area at PlumbersForums.net
Matty Birch
pricing up a heat only swap here just want to know what's involved. Baxi solo2 customer wants the main compact (no pump over run I believe).
Haven't looked for the compact wiring diagram yet but is this going to be straight forward for me?
Thanks in advance 🙏
Pump live and boiler switch live
yep or you can swap it for what you need
Yep or you could change it in the wiring centre upto you
and just make safe of the perm live eg constant 240v if it doesn’t require permanent live
Thanks in advance 🙏
Just call a professional electrical engineer and have the job performed correctly. Its why they are professional qualified engineers. Don't mess with things you are not certified and professionally qualified to perform. Leave that to the professionals
He is qualified to work on any electrics that are the boiler side of the spur. Hope all goes well Matty.
Reply to little wiring help 🙏❤ in the Central Heating Forum area at PlumbersForums.net
