Discuss Location of boiler acceptable or not in the Plumbing Jobs | The Job-board area at PlumbersForums.net
O
Old Account
as the tilte says, is the boiler above the ink acceptable or not?
Apparently a customer of mine got told that the boiler can’t be fitted above the sink? She asked me to give her a quote for a replacement of the boiler.
What’s your thoughts?
Regards
Ron
Yes fine
Why do you think there’s a problem
It’s not the best but acceptable especially if there’s no where else eg small flat
It’s a house and the system got converted 10 years ago. I assume she does not want to move the boiler although she mentioned it bothers her that she can smell the plume a little. I’d say the flue is too close to the window it’s less than 300 but bigger than 200mm. Perhaps a plume kit will be necessary or moving the boiler
Hope you turned it off / tested to see if the gases were coming back in when you were there
Reply to Location of boiler acceptable or not in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All, We have finally decided after a bit of a persuasion to have installed a utility room in our garage that currently houses our oil boiler...
Hi everyone, I have been searching the Web for a spare part for a Worcester 35 cdi ng boiler that is obsolete. I can't find one anywhere and its...
Deleted member 120897
Hi All, In Dec 2023 I had my annual boiler service and asked the plumber to change 2 radiator valves as the radiator in the toilet downstairs was...
Hi Everyone, For those who like a long read but I could rally do with some advice. Might be a bit long this. For background. A...
Context for issue: I'd like to start by saying I'd rather not read 100 "Hire a professional comments", I will do that when/if it comes to it, but...
Butchy10
