H
Discuss Lock shield drain offs in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Go on then do tell. What's the secret?carnt believe they don't know how to use em !! plumbers lol
i'd crack them open before you install, i've had a few impossible to open ending up rounding.Lol
Close both valves. Open drain off. Attach hose. Open bleed screw. Simples.
clutching at straws my friend,honesty best policy.. Much easier the normal type so what ya meant to do the valves dont close properly like the last job i did. you just put up with the mess I guess
The one pictured is where you remove the small rubber cap and use a rad key to open drain off. No mess involved. The op must mean some of the other types where you have to unscrew the drain off part of the fitting
Reply to Lock shield drain offs in the Plumbing Jobs | The Job-board area at PlumbersForums.net
