Discuss Logic combi 30 L2 Fault code - won't reset ..help please. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
K
kx07fdp
I've got a fault finding book given to me by Logic.
The possible faults in order are:
Replace gas valve.
If above fine, replace Spark generator
If above fine, replace Ignition Electrode
Could anyone give me an idea of costs involved on the above scenarios
(I'm from Newcastle upon Tyne)
Reply to Logic combi 30 L2 Fault code - won't reset ..help please. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Morco feb 24ed3 has a f1 fault code. The burner reading is fine. The fault is intermittent, sometimes the boiler won't ignite on either hot water...
Hi, As per the thread title, I have an Ideal Logic Combi 30 and I am having a problem with the pump, which keeps activating without any DHW/DCH...
1K
Hi all, having an issue with a Logic Heat Only. On a few occasions early this year the boiler was going to fault code L2/F2. The electrodes, gas...
2K
Deleted member 120897
Attended job today on logic heat 12, l2 fault code. 240v present at spark gen and electrodes in decent condition. Replaced spark gen and...
Morning - hoping someone can help with a problem we've had for two days. Our iMini 30 Combi boiler doesn't seem to be working consistently. We're...
5K
