Discuss London Flat Living: Issues with Leaks from upstairs! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I've had 5 leaks from my upstairs neighbour in the last 18 months and I've had enough. I believe that the joint seals are coming to the end of their lifespan as nothing has been touched since the renovation and install over 40 years ago.
My questions is......is there a way to identify weakness in her pipe system? some sort or pressure test? or tech solution? I'm sure there is?
Please advise!
Thank you for taking time to read this, looking forward to your responses
DIY-NEWB
As this is a flat are they rentals ? or are leaseholds. Either way the owner or the freeholder has a specific role in this issue. Regular inconvenience can render the offending leaseholders contract void.
If you are a freeholder then the local authority can intervene or a letter of intent before action might move things along.
centralheatking
Leaks from where? Bathroom, kitchen,heating, unknown?
2 from the kitchen area in the last 8 months, and 3 from her Bathroom area in the last few years. It's more the regularity of these leaks, she said it's unfortunate but I'd like her to take a pro-active step and test the system some how.
[automerge]1565850387[/automerge]
Why are you concerning yourself with why it is happening?
Send them the "make good" bill every single time.
Next time it could be a massive leak when no-one is around and flood my entire flat.
[automerge]1565850521[/automerge]
centralheatking
Thanks, I think we're at that stage now....using the lease and T&Cs against her...it is a regular inconvenience and a massive headache when this happens
Could be pinholing, in which case may need a full new pipe install, but if it's a landlord they may just want the cheapest short term fix?
It's resident who's been there for 33 years but has done nothing to maintain their property, and yes...I understand that they don't want to spend money as would I but when It's the 5th leak it's time for action...I've had enough!
Thanks for all the replys.
Roughly how old is your neighbour. Are you sure that they are leaks and not that the flat-owner is becoming forgetful and leaving taps running? They may be saying these are 'leaks' because they are embarassed to admit what really happened.
Reply to London Flat Living: Issues with Leaks from upstairs! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello I am looking to install a slimline dishwasher (integrated) into a cupboard in my kitchen. The depth of the dishwasher is 550mm and the...
