Discuss Long loud Noise after flushing the toilet in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sedgy40
was at a friends house in Wiltshire the weekend,3story house toilet on each floor flushed the loo there middle floor and it made a very long loud noise.
Is that pressure too high on cold main as it fills cistern?
Thanks in advance
You can just change the diaphragm washer inside the fill valve.
That
The noise is because the washer is vibrating with flow of water. Reducing the flow with the tap will lessen the sound.
That
Thanks I will pass on the info.
Reply to Long loud Noise after flushing the toilet in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
Hi all, seeking advice on my toilet. (Layman here, please be gentle with me.) When we flush the loo upstairs, it flushes fine (therefore assuming no suggestion of any actual blockage) but after the flush we get a rumbly gurgling from deep within the pipework somewhere and the water level in the...
Toilet continuously flushing/cistern filling. This happens regardless of what else is going on within the house (videos were taken before and after a shower but this happens seemingly randomly and probably happens when no one is home). As a result my water bill has considerably increased but I...
This issue arose about a year ago. Does anyone have an idea why I occasionally hear (about once every hour or longer) a hammer related noise coming from my copper water pipes when no water is being used? It basically sounds like the noise you hear after the water shuts off when your toilet bowl...
Hello, I'm seeking advice on resolving the persistent blockage issues with my downstairs toilet. A year ago, I replaced an 80s close-coupled toilet with a more affordable model. This new toilet is a back-to-wall type featuring a concealed cistern within a separate unit. Since its installation...
When we moved into our house in 2016, the electric water heater popped loudly when heating. After awhile, I researched and realized that it was likely due to limescale and/or other sediment buildup. I flushed it multiple times, but never got it to stop popping, so I eventually decided to replace...
