Discuss Long loud Noise after flushing the toilet in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sedgy40
was at a friends house in Wiltshire the weekend,3story house toilet on each floor flushed the loo there middle floor and it made a very long loud noise.
Is that pressure too high on cold main as it fills cistern?
Thanks in advance
You can just change the diaphragm washer inside the fill valve.
That
The noise is because the washer is vibrating with flow of water. Reducing the flow with the tap will lessen the sound.
That
Thanks I will pass on the info.
Reply to Long loud Noise after flushing the toilet in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all Noticed bad smell in my drain out side put my hand down and it unclogged it for now however I checked my sewer drain and after flushing my...
The left rear floor corner is highest (the shower pan touches/sits on the floor), sloping down diagonally to the front right corner (lowest). The...
I have a green star ten yrs old keeps increasing pressure, feel on off filling valve not working, drain off to recommended, but after few days...
