Discuss Looking for input on my plan for two bathrooms. in the DIY Plumbing Forum area at PlumbersForums.net
Hi All! first post. 👍
Im starting to put together a plan to put two bathrooms in my house. I'm looking for some input on my plan. Ive made a rough diagram of what I want to do and routing of vents and drains and could use some advice.
Does the vent setup work? Any code issues or anything I should be aware of?
What kind of 4 way can I use at the second floor WC? would a 4x4x2x2 santitary tee be ok? I see they dont have turn downs for the 2" side ports, not sure if that's a problem.
Anything else?
If you're converting your basement into a bedroom, guest room, or rentable unit, adding a bathroom is highly recommended. If you're wondering how to finish a basement bathroom rough in plumbing, remember that The proper pipe spacing and pipe distance from the floor should be well planned. The necessary holes and cuts in the wall are made for the installation of the pipes and fixtures.
Reply to Looking for input on my plan for two bathrooms. in the DIY Plumbing Forum area at PlumbersForums.net
