Discuss Loss of water to toilet cistern in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Suddenly my downstairs toilet stopped filling this week, I suspected a blockage in the filter or cistern itself, however after removal of everything it appears that there is no water coming in, its mains fed and no sign of leak anywhere , we have checked the isolation valve and its not faulty, the pipe below has this connector on it? can anyone advise, there also seems to be a similar fitting on the pipe as it disappears into the wall. Both me and my plumber are flummoxed! Could it be blocked? have used a vaccum on it .. any ideas very welcome, all other taps etc in the house are fine, which is why it seems very odd.
Seems odd!
You say you’ve checked the isolation valve (not pictured) , if you crack open the nut on the live side of the isolation valve does no water come out?
There must be another isolation valve further downstream- you say it suddenly stopped filling - have you had any work done in the house recently, even unrelated to plumbing, someone may have turned off a valve.
Maybe to an outside tap to overwinter it? I have seen these plumbed incorrectly such that they can’t be isolated independently.
Seems odd!
This is what is so odd, my plumber came yesterday expecting a quick fix and was very suprised to find no water in the pipe, he asked all the same questions, but we havnt changed a thing and my outside tap is still on and working a i use it daily for animal care. The only conclusion we have come to is debris in the pipe, it could have been getting blocked over time and we didnt notice as its just a loo filling you dont see the flow but it does seem extremely unlikely. Heres a pic of all the pipework that is visible,
A long shot, but if the house is plumbed in plastic, maybe a section that was bent around a tight corner or kinked has decided its time to collapse further.
Thanks thats a good point, I believe it is plumbed in plastic, house was built around 2000, my brother thought this might be an answer, my concern is that it will crack and eventually burst wherever it is!!( is this likely??) My plumber as suggested capping it and putting in a new supply from the nearby utility which solves the problem but is always going to worry me! however without taking the wall down and tracing the pipe i guess i dont have a load of other options.
Another issue, it's bad practice to cap pipes in this manner without also isolating them from the supply at the other end. This is because you create a 'blind' section of stagnant water that can act as a source of infection.
One trick that sometimes helps is to feed an electrician's fish tape into the plastic pipe and then use a pipe finder to trace its path. A borescope can be helpful too as it allows you to look inside cavities through a relatively small holes so that making good is a job for a decorator rather than a builder.
Reply to Loss of water to toilet cistern in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
We have recently had water hammer issues. Plumbers have installed an arrestor near our kitchen sink and a device in the toilet cistern to slow...
Hello, I'm seeking advice on resolving the persistent blockage issues with my downstairs toilet. A year ago, I replaced an 80s close-coupled...
I wonder if anyone is able to help with advice on this. We have fitted a new toilet and 6 litre cistern .. it flushes .. but not as efficiently as...
2K
Hi - I'm not an expert but wondered if anyone might be able to assist. I've replaced an old toilet with a new one. I've used the same water inlet...
2K
C
Hello My toilet flush is busted. The tank takes about 10 seconds to empty and it’s kind of showers down from the middle, rather than that sudden...
Chris P
C
