Discuss Loss of water to toilet cistern in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Another issue, it's bad practice to cap pipes in this manner without also isolating them from the supply at the other end. This is because you create a 'blind' section of stagnant water that can act as a source of infection.
One trick that sometimes helps is to feed an electrician's fish tape into the plastic pipe and then use a pipe finder to trace its path. A borescope can be helpful too as it allows you to look inside cavities through a relatively small holes so that making good is a job for a decorator rather than a builder.
Thanks Chuck, I hadn't thought of the water sitting in the pipe, The ideas you have mentioned are all great and something I can be working on, we could get lucky and the issue could be right near the loo my worry is that is in the wall behind the very expensive kitchen units put in last year, one does wonder whether they have managed to do something to a pipe in the wall during the fitting?? whatever way its going to be costing me a few quid to get sorted which all having only been in just over a year I could do without! Many thanks for your ideas! I will order a borescope, it looks to be a useful bit of kit to have anyway.
Hi Chuck, I had a really helpful young plumber round today and we discovered there there is a plastic cap of some kind blocking the pipe completely, it must have been in there since the house was built 20 years ago and reduced the flow on the pipe but we had never noticed till now when it must have moved and got wedged on one of the joints. It may have done us a favour in a way as the installer of the loo last year managed to put a screw through the pipe as well so if it had been at mains pressure we would have had a leak which could have done some serious damage. Its not repaired yet but at leas we know why there is no water and we have a plan to resolve. Was lovely to have a young person with great skills and a keenness to get it sorted which is more than can be said for the original installer and was the one who put the screw through the pipe!
Reply to Loss of water to toilet cistern in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Sonya K
