Discuss Loud rumbles/banging from boiler and no hot water / heating (with audio) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
ben341
Hi there,
We have a Worcester 24i Junior Combi boiler. The house is rented and I have no information about service or installation history, the agent don't have this info. I do know the house was empty for 6 months, including when it was cold around last xmas/Jan although frost mode was enabled.
Hot water has been fine since moving in 3 months ago. I set heating timer a couple of weeks ago, and the heating kicked in for the first time last Saturday afternoon while we were out. We did come home to a warm house.
However on Saturday evening when trying to run a bath the boiler started to make loud noises:
Bubbling
Low volume groaning
Occasionally, perhaps once every two minutes it will make incredibly load groaning noises. They are hard to describe but tend to make you jump and if it isn't too dramatic, it reminds me just of the noise the machines made in the Tom Cruise version of War of the worlds.
I have attached an audio clip https://www.dropbox.com/s/5ne4dne17buznmi/boiler-audio.mp3?dl=0
(you don't have to create an account, the file is about 2.3mb)
In the video I turn the hot tap on twice after the half way mark, but no hot water is produced.
Last Saturday I turned the boiler off after failing to get it working, and dripping water from the rivet in the case towards the bottom right, rivet nearest the wall. I had previously bled the radiators, and got a little air from one of them, but nothing significant.
We called the letting agent on Monday, they sent someone Mon afternoon to look at it. He said it was just prssure (about 0.7 bar - this had not reduced when I bled the radiators) and demonstrated how to let water in. He did not do the pressure, but turned it on at .7 bar for 20 min and it behaved perfectly.
We increased this to 1.5bar, turned the boiler on, it made some noises Monday night so switched it off again. My partner turned it back on Tuesday morning and she said it didn't make any noises, behaved normally with heating and hot water and has done so until tonight, where it is as recorded, heating won't come on and water won't heat up.
The end of this clip is the boiler cutting out, and the reset light flashing, which is what happens over and over.
As this appears to be an intermittent issue, what I would like really is whether I should be just calling the letting agent again and insisting someone looks at it, and perhaps some ideas to give the engineer. As it gets colder and I have small children I'm concerned the boiler will get worse, and definitely don't want to use it if it is dangerous and/or continuing to just try using it will cause it to fail unnecessarily.
Please help, I would very much appreciate your expert thoughts!
If it does help, one extra thing is I noticed the radiators do bang a little when first coming on, as if they need bleeding, however there is no air in any of them, I checked again tonight. I think the whole CH system is reasonably new within the past few years. The radiators and boiler were the only things that were clean when I took the house!
Thanks again
Ben
if the boiler pressure is above 1 and below 1.5 (cold) your fine other than that sorry to say you need a gas safe eng to have a look phone the letting agents up
OK thanks. I guess what I also want to know is, is it safe for me to keep trying it and try and get it into a working mode again until someone can look at it (so I don't have another weekend without hot water) or should I switch it off and leave it off?
theres enough safety devices inside but if your that concerned turn it off
Thanks, as long as it isn't negligent to keep trying to get it going then that's what I will do.
When I was decorating the house before I moved stuff in, I did balance the radiators. The heating worked then and I didn't notice any noises but was only on long enough for me to know which order they heated up in. I then closed all the lock valves and opened the first one by 3/4 turn and then the rest in order by about an additional 1/4 turn (I don't have a thermometer).
As I didn't test the system before this I don't know if it is related. Is it possible I have restricted the flow or something similar by doing this which would cause such behaviour? Is it worth my while to fully open all the lock valves to test?
I think I can get the hot water to work reliably as long as I switch the CH off. I'm not going to keep trying to get the heating to work there is quite a lot of water coming out of it now from that rivet location. I was surprised the engineer on Monday didn't think a leak was significant so perhaps I'm over-reacting.
Reply to Loud rumbles/banging from boiler and no hot water / heating (with audio) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi guys, just want to get some advise, basically new vaillant regular boiler has been fitted approx 5 yrs ago, i believe it was back boiler...
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new...
MartinPod81
M
Desperate for some help! Be a life saver of someone can help as suffer from a high intolerance to noise. Moved into new house 1940s (copper...
Afternoon. I have an issue with no water flow from any of the hot taps in the house, I can't seem to find a solution to the issue. System is a...
Hi all, just moved a radiator from one wall to another, straight forward job, heating is working, problem is that on turning on a hot water tap...
