Discuss low pressure hot water in most of street in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
Theladyplumber
more help required please, low hot water pressure from customer, went round, got it sorted, two days later same problem, its just trickling out, whilst I was there three of the neighbours came to tell me that they had lost all hot water pressure too, had three more calls this moring from the same street with the same problem......most of the street has lost hot water pressure within the last couple days....any suggestions will be greatly appreciated, thanks
karen
hot water , not cold??
or is it cold pressure and they all have combi boilers, and the cold pressure is also down??
is is some localised hot water system that everyone uses??
if so then it the water board or whoever manages the water??
Sounds like a local problem, Water Board or mains burst in vicinity. Check with local water company.
This is definitely a burst hot water main. Easy to spot, there'll be steam.....
Honestly? You've never seen a burst hot main?
They're kind of difficult to miss.
People have been taking me literally all my life.
I went to a job once where someone had piped the dunny up to the hot water. Teed off the wrong pipe.
No hot water mains down here but have seen steam from turds in the sewer :)
Reply to low pressure hot water in most of street in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello All, I wonder if you can help me? I have intermittent hot water low flow from all taps in my 4 bedroom house upstairs and downstairs. I...
Low hot water pressure Hi everyone, I'm hoping someone is able to shed some light on my situation before I have to call out the professionals...
I have just had a boiler, hot water tank and power shower pump replaced on advice by my plumber. I have two separate boilers, heat/hotwater...
First post as I can not figure this one out. I have a hot water boiler heating system, gas fired, with an HTP SuperStor indirect hot water tank...
