Discuss Macerator Part Query in the USA area at PlumbersForums.net
Nope doesn’t open for me
Is it a link to a picture from another site or direct from your own device ?
What is part 445 called and following on from the above, try downloading the picture to your PC first then using it here.
I’ve attached image of the part, it appears the 2 small sticking out lugs which connect to the other end are broken off so my question was would there be any way to affix it back without replacing but ensuring water tight etc
Reply to Macerator Part Query in the USA area at PlumbersForums.net
The left rear floor corner is highest (the shower pan touches/sits on the floor), sloping down diagonally to the front right corner (lowest). The...
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few...
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
