Discuss Macerator Waste Advice in the USA area at PlumbersForums.net
Hi
So I am adding an en-suite to a downstairs bedroom and have to install a macerator. I will be using the SaniPlus Up.
I was trying to get a professional macerator fitter but can't get anyone in the time frame (in the next 10 days) so I am trying to fit the waste piping from the macerator. Everything else is in place and ready to go.
Looking at the macerator manual, it has either a 22mm, 28mm or a 32mm optional waste out. Obviously, the smaller diameter, it will be easier to run the pipe in the house so I do want to go 22mm for the vertical run and then change it then.
My questions:
  1. If I use the 22mm from the Saniflo, is that copper or plastic (non-flexible?)
  2. From the 22mm, after the vertical run, should I then change to 32mm or 40mm? I couldn't find an adapter off google or the main supplier that does that, is it not standard?
  3. Is it better to run a 32mm from the saniflo, and then just keep it 32mm all the way to the soil stack? if so, again, is that copper or plastic?
Thanks again
Hi
My questions:
Thanks again
1 Solid solvent weld plastic
2 There should be a 22-32mm step up adaptor in the bag of bits
3 Will need a detailed answer or sketch of the pipe run including any verticals and all measurements of pipe run (roughly) to answer.
Reply to Macerator Waste Advice in the USA area at PlumbersForums.net
