Discuss Main 30 DHW pin not coming out far enough in the Plumbing Jobs | The Job-board area at PlumbersForums.net
MK Heating
Just short of the micro switch. What's normal procedure for this? I work a lot on these boilers, but not had this one yet. Diaphragm kit suffice?
Use a brilo pad to clean inside of diaphragm chamber. Also make sure pipes from hydro block are clear. No need to drain boiler just switch off cold under boiler and run off hot water. Take note of what order it came apart . Undo opposite screws on block and put pressure against it when y remove last screw. Shove towel along base of pcb to catch any drips. If u do get pcb wet..... Hair dryer !
Sorry just re read your last post.... Granny here is an egg.
Reply to Main 30 DHW pin not coming out far enough in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Folks, I have a challenge with a Main Eco Elite 30 Combi which is short cycling on the CH. Water works fine. As soon as you have call for...
Conditions: nearly 10 year old boiler WB2B, heating mode off, DHW on or also in standby, Boiler shows no fault LED on, no new fault logged, room...
Hi, I have a problem with Viessmann 111w I have a Vicare sensor and app. It goes like this : If I have a boiler in DHW only everything works as...
1K
1K
Hello all, I have a WorcesterBosch Greenstar 42CDi classic combi, which is providing DHW fine, but not heating. Was working fine in spring...
1K
