Discuss Main Combi 30 Eco Elitie Temperature Issues in the Gas Engineers Forum area at PlumbersForums.net
Sandeep89
Hi Guys,
Just changed a sink tap for customer and when turned the hot water on the boiler temp rose to 90 within few seconds and burner cut out, temp came down to 78 and the boiler then fired up again and keeps cycling like this.
Customer said this has been happening for a few months now, I noticed the return pipe was hot as well and the flow pipe was cold and heating was off.
Could the temperature rising so quick be due to a faulty diverter valve or would it be the plate heat exhange, or a sensor.
Any help would be appreciated.
Hi Sandeep89
Does the CH work ok, or does it cut-out through overheat too? If so, providing the pump is ok, it's a blockage in the main heat-exchanger.
If the CH is fine, it's a blockage on the plate heat-exchanger.
Hi Sandeep89
Hi WelshAndy,
CH is working fine customer has said no issues on that just the DHW.
Checked the pump, removed the bleed screw and pump looks all good.
Reply to Main Combi 30 Eco Elitie Temperature Issues in the Gas Engineers Forum area at PlumbersForums.net
Hi Folks, I have a challenge with a Main Eco Elite 30 Combi which is short cycling on the CH. Water works fine. As soon as you have call for...
Hi, I'm hoping someone here may be able to help me out with an issue I have with my baxi duotec boiler. Basically, the hot water temperature has...
WB 4000 installed a few months back, just balanced the 7 rads - managed to get around 15 degrees delta across most rads. Not quite the 20 degrees...
Morning all, I have a Worcester Bosch 8000 life 40kw boiler on system with 7 radiators and the boiler is located in the loft of a 1907 end of...
Background 24 apartments are equipped with thermal stores of (100 to 150 litres) with immersion heater capability. Individual demand of each...
